Diesel heater pickup tube leaking
forbin
Nov 4, 2013
166
Tartan 3700 Seattle - Elliot Bay
The standpipe provided by Wallas looks like the following: wallas furnace fuel standpipe Hard to see, but the toggle plate is beneath the nut, washer and gasket that mounts on the outside of the tank, while the toggle plate tilts into place inside through the tank hole; simple, effective and secure.
Thanks Terry. Coincidentally, the first problem we had on the prior boat was the diesel heater pickup tube and they replaced it with the setup you described, and we had no issues with it from that point forward. It was a bit of a mess at the beginning though because the prior gasket cracked and was leaking a decent amount of diesel in to the bilge when we were sailing...glad that didn't turn in to a disaster.
I talked to Sure Marine, their advice aligns with everything here.
Brian
74
South P10 Pugetopolis
Good news, hope this issue sorts itself out easily for you now that you connected with the manufacturer.
