Diesel Heater help!
A
Art Barnes
I recently got around to try and fire up my diesel heater on board my 1979 H37C; I have only owned the boat a year. I never have tried it before, but wanted to understand how it works. It has no name on the heater, but I understand it was placed at the Hunter factory (in the cabin )when the first owner took possession as an after market heater, accessory and option. It fills the gravity flow diesel tank by way of a fuel pump (electical) located on the Yarmar engine. The problem I can't figure out is to heat it first so that the dripping of the oil will commencing vaporizing or whatever it does to create heat. I am told you squirt alcohol in the small compartment it has and light it to get the iron plate hot enough to vaporize the drips of oil you set by a small valve for different amount of temp. Could any of you inform me if this is correct, how much alcohol to use, ect? Or, if this is not correct, how do I fire the darn thing up? I am planning a trip up North and it would be nice to have it working correctly. I assume most of these diesel heaters work alot alike but I just have never had the opportunity to have one on any of my other boats before. But before I go squirting alcohol in the hold and causing a fire it would be good to know that it works like that. The heater is vented and a heat shield is correctly in place, everything looks as if it did when it was installed. Please help! Art Barnes
Jim Legere
Dickinson?
Sounds like it might be a Dickinson stove (or a copy of one). Try their site at the link below. At very least, you could download a set of operating instructions for their stove, which might get you going. Dickinson stoves are excellent units.
Ray Bowles
Art, I have no idea about starting you stove as
the factory manual would say to do, but I do have experence with an old diesel farm heater. We would use a mixture af 75% diesel and 25% alcohol and soak a cotton ball. Then light it with one of those long butane candle lighters. (overgrown cigarette lighter)It's a lot easier than watching the people on "survivor". Ray
N
Neil
HI SEAS
It sounds like the one I have in my 34 ('84). Could you give me a bit more of a description. If it is the same, I have a factory (long out of business) brochure that tells how to operate and maintain it. By the way I have used mine as low as 25 and we were in tee shirts. You can contact me directly wordbird@telisphere.com
Barry
If it's like the Kenyon stove .....
it required preheat using alcohol. On my stove I use a benzomatic propane torch to do the preheat. It's quicker and cleaner than using alcohol. After preheat turn it on and away it goes. Barry
