Diesel biocide
Lotta different opinions here, so here's mine.Gas is different, and most of my experience is diesel so I'll stick to diesel.1) for fishermen it is a given, "keep tanks full" and for knowledgable recreational p/v skippers too.2) I crusied my sailboat in the tropics for five years and ALL the cruisers I knew, hundreds over the 5yr period, kept their tanks full, and added biocide to kill critters.3) Even in northern latitudes, above 38 N. the folks I know (sailors) keep tanks full, and most use biocide.4) I have had, rust, moisture (from a tank being left 1/2 full allowing condensation), and bacteria in diesel tanks, never had "bad" diesel from letting it sit.5) If you run your tank dry you will suck air and need to bleed the injectors; done in a controlled environment, it seems mucho work for naught."an that's all I gotta say 'bout that" Forest Gump.
