Diesel Fuel tank grounding?
Feb 6, 1998
11,722
The fuel fill hose, deck fitting to tank, should be "wired". A wire is integral to the hose construction so it is connected top and bottom making a contiguous electrical path.
The hose wire should not be used for this purpose. A simple green wire tied to the metal fitting or to one of the bolts that secures it than down to the tanks "grounding tab" is the preferred method.
Oct 29, 2012
354
Catalina 30 TRBS MkII Milwaukee
Bonded together, more correctly
