Maine, et al.
I was down in the bowels of my recently acquired Catalina the other day trying to clean up some of the old wiring. I came across a couple of wire connections to the fuel tank and I'm wondering if you guys can help me puzzle this out:
(The attached photo shows the two black wires that I found, one is connected to the centre of the top access port, the other connects to the rim. I traced them out and one wire goes to a negative bus bar (which was apparently unconnected to the DC system anymore) and the other was just hanging loose under the same bus bar, below a bunch of gear. It seemed to have had no previous local connection. The wire looked cut (on purpose or accident) but there was no corresponding terminal end on the bus bar, nor any other errant comparable wire. Very strange.
1. Anyone know what they could be for? Are you supposed to ground your tank?
2. The PO told me that the tank (installed in 2006) was set up for having a fuel gauge, but had never been 'connected' up. Could this have been related to the wires?
3. It looks like the rim of that access port has a male connector tab on one of the screws, so I assume the factory meant for the tank to have a connection.
Thanks all!
Mike
Thanks all!
Mike
