Irwin Citation (1979) 34' Refurbish questions
Hi ,
I am refurbishing my 1979 34' Irwin. I have some questions that perhaps you may be able to help:
1. Diesel Fuel Tank
I removed the diesel fuel tank lid to clean out the tank. In so doing, I now need to replace the lid and seal it. There was some type of gasket that was used between the lid cover and the tank. The lid was constructed of 3/4" plywood encased in fiber glass. I purchased a good grade of 3/4" exterior plywood and fashioned a new cover, which I plan on encasing with fiberglass cloth and resin. I have been unsuccessful in locating a replacement gasket. Does anyone know where I might obtain a gasket? My backup plan is to use 3M 5200 sealant, if I am unable to find a gasket. Is that a viable option?
2. Engine upgrade
My Irwin is currently equipped with a 20 HP Yanmar diesel engine. I removed the engine from the boat for general maintenance, replacement of a defective water pump and repair of a broken oil line. I am considering upgrading to a larger diesel engine, perhaps a 30 HP diesel, if I can find a good used one. Does anyone know where I might look for an engine and also for a water pump and oil line?
3. Floor replacement
I am also replacing the flooring and thought that I would use teak or a synthetic material. Does anyone have an experience with flooring materials?
Any help with answers to the above would be most appreciated. Thanks.
Regards,
Tony
Hi ,
1. Diesel Fuel Tank
2. Engine upgrade
Regards,
Tony
