I recently purchased a Hunter 28.5. I have diesel fuel in bilge but I cannot find tithe source of the leak. Any suggestions? Brenda Reiland
Thanks. This is good information. What is an oil absorbant dog boneKD3PC said:first get some oil absorbing dog bones in there pronto....if your bilge pump comes on and dumps this over....you may have some very expensive fines...
next you will want to clean and inspect every nook cranny and notch of the engine, fuel lines, filters, fills, tanks, etc...
the key is cleanliness, as you will not be able to see anything but a flood with dirty engine and bilges...
if the engine runs well and strong and meets it's specs, then you can look on the low pressure side and towards filters and tanks...as fuel leaks enough to show will usually cause an engine to miss
Thanks. This is good information. What is an oil absorbant dog bone?
