A
Atina
I would like your thoughts on diesel fuel and fungus problems. I have a Cat. 30, 1991 with a Universal motor, and @l8 gal. metal tank. About 3 years I had a serious fuel fungus problem where the marina said they washed the tank out and changed the primary and 2ndary fuel filters. Mind you prior I have used fuel additives, water absorbers and biocide spring and fall. Prior to the fungal problem I just topped off the tank each fall. I use about 8 gals. fuel a year. Since the problem I pump out the fuel and replace each fall. Well, to make a long story short, the problems have come back 3 years latter with the motor cutting out and fungus in the cup of the primary fuel filter. I would like suggestions so I can correct this problem myself on a more permanent basis. Has anyone used a hand sprayer, like a garden sprayer with diesel fuel to try to clean the inside of the tank? The tank is bigger than the hole so removing it would pose a problem.
