Are you familar with how your hand prime pump feels when it is actually pumping fuel? It may take many pumps before it is really moving fuel. My first time I gave up before I really had enough pressure to purge. In my limited experience, once you have pumped up pressure, they bleed best by just barely cracking the line nut at injector. If you get a lot of air, you might bleed it twice.
