relatively cheap but effective alternative
With the discussion on VHF range and hand held radio (antenna) limitation, some might want to consider the following alternative -As in real estate, it's all about location. In this context, it's all about the location (above water level) that determines the range of any VHF siggnal, almost regardless of whether its a 25 W fixed transceiver or a 1 W handheld.Exaggeration for effect - if you climbed the mast with a handheld, the range would be almost equivalent to that of a fixed radio with mast mounted antenna, particularly when you consider the signal loss inherent in the coax.In an emergency, the alternative consists of a small cheap adapter, available at most any electronics store, with which one can connect the mast mounted antenna coax directly to the handheld. In an emergency or when the fixed radio does not work, it is possible to connect the handheld directly to the mast antenna thereby significantly increaing it's range.
