Step by step
To post the picture I have with this message, I did the following:Using my software (ACDSee) I took my original JPG 1600x1200 image, which was 803KB, and resized it to 640x480 and saved it under a new name. There should be no need to change the dpi, since on screen each dot, or pixel, displays independently so "dots per inch" is somewhat of an irrelevant concept (applies more to printing). The new file is 65.6KB in size. The image must be less than 80KB.I wrote the text you're reading and checked off the "I have a photo to post with my reply!" box and then clicked the "Acknowledge and Submit" button. On the next screen I clicked the "Browse" button to find and select the image file on my computer. When the dialog box closed I clicked on the "upload" button. The next page should show your picture. If it's there and looks right, just click the right button and you should be done.If you followed this process, and it still didn't work, then maybe there's another problem.Hope that helps.Ron Mehringer
