Diagonal mainsail crease
Jul 31, 2010
37
Catalina Capri 22 39 Seneca, SC
My main has a large diagonal crease, more pronounced upwind. It remains regardless of the basic adjustments - halyard, cunningham, etc. Any suggestions on how to remove the crease?
Thanks
Catalina 320 Dana Point
The tack seems above the boom and perhaps rigged to the cunningham in such a way that the luff is not properly tensioned by the halyard.
JBP-PA
Apr 29, 2022
711
Jeanneau Tonic 23 Erie, PA
In the photo it looks like your first reef line is too tight. Also more halyard tension should help.
Likes: BarryL
Oct 26, 2010
2,173
Hunter 40.5 Beaufort, SC
I assume this is a loose footed main. It could be an optical illusion, but it looks like the foot, about 1/3 back is somehow captured or caught so that the tack and the clew are above the boom but the center of the main is not loose footed, distorting the shape of the sail.
Jun 9, 2008
16
hunter -- -
Try adjusting the line in the luff that holds the first sail slug (above the tack). I've seen that do weird things to the sail shape. Also do you get any resistance when you raise the main when you get to the spreaders? One other thing is the way the cunningham is rigged, try putting a stopper knot of some sort at the high point rather than the loop that is there.
Jun 11, 2004
1,862
Oday 31 Redondo Beach
Possibly a shrunken bolt rope?
Lots of hits for a web search for shrunken bolt ropes.
386
Tighten the halyard... and make sure your vang is eased while you do it..
DaveJ
Apr 2, 2013
516
As above, make sure vang, main sheet, Cunningham, reef lines, outhaul are all loose. Raise mainsail and adjust all other lines accordingly.
cheers
Jun 11, 2004
1,862
Agree with the the two above it does look like the vang is on and the leech is tight thus possibly preventing a full hoist.
Also as mentioned the reef line also looks too tight.
Sometimes it's the simple things. Hope that's it.
Oct 31, 2022
72
Catalina Capri 22 Huntington
Just read this on the UIlman Sails tuning guide: "To determine your maximum backstay adjustment, pull the backstay on until the main develops wrinkles from the middle of the mast to the clew. Place a couple of marks on the backstay for a quick visual reference. This will be your maximum backstay adjustment. "
Could your backstay be to tight?
