Vega friends,
I have an outboard with two fuel tanks and a central water filter. I believe I've gotten an air leak in one of my lines either between one of the two tanks and the filter or between the filter and the fitting for the line that connects to the outboard. When I tried to pump fuel up to the outboard, I got nothing. I tried two different external lines with built in primer bulbs; neither worked. When I attached one of them to my portable auxilary tank it primed right away. All the fuel lines run under the deck.Any ideas?
Bruce
S/v Cygnet #169
Bruce
S/v Cygnet #169
