Design plans/documentation of 1993 Hunter Legend 43
8
Hunter Legend 43 Puerto Del Rey Ceiba , Puerto Rico
I am the proud owner of a 1993 Hunter Legend 43 and sail extensively in the Caribbean. I am taking small amount of water in my bilge that is coming up through hair line creaks in the floor of the forward section of bilge across from the keel bolts. Before I decide dropping the keel @ the next haul out in May of this year I am looking for any design plans/document for this model and year vessel that I can use in understanding and correcting the problem as well as understand the structure of this section of the vessel.
I would appreciate any help and advice.
JM
G
Guest
Leaks
Hmmm, does not sound good. Water should not be leaking into the bilge area through fine cracks in the hull, if that is what you mean. If the boat keel strikes a solid object while underway, that will cause the hull area in front of and behind the keel stub to flex. If the strike is hard enough the FRP can fracture in the flex area and water will leak in through those cracks.
If it were my boat and that I understand what you describe, I would hire a marine surveyor to inspect the area for hull FRP damage. Hunter normally does not provide hull design documentation with boat delivery. You could call Hunter Marine Customer Service, but without actually seeing what you describe, they would probably defer you to a marine surveyor.
Assuming that you hired a marine surveyor to inspect the boat before you purchased it, which means the boat would have been hauled for the surveyor to do a thorough hull inspection, they should have noticed leaks of this type. The keel and keel stub joint would show some evidence of a strike hard enough to cause fine cracks in the hull area you describe.
Terry cox
Apr 12, 2009
8
Terry;
Many thanks for your quick reply. I want sailing yesterday and after returning I noticed that the bilge had about 1/2'' of water. Before leaving I cleaned and left it partically dry. Today I went back and it was still pretty dry. Is there anyway that I can get some pictures to you that I took of the bilge that show the cracks?
JM
G
Guest
Leaks
You can post the pictures in this forum for all to see. Hunter used the same hull mold to build our boat model, the 1991 P42. I would be happy to render an opinion of which I never seem to be short of. Can you actually see evidence of water seeping from these fine cracks?
Did you have the boat surveyed before you purchased her? This is an important question, perhaps moot after the fact, but possibly some potential regress if a surveyor was involved.
Terry Cox
Apr 12, 2009
8
I've had her for over 6 years now and yes I had a survey of her outside the water before she was purchased. All was found to be fine except for a blister here and there and these were taken care of. I’ve posted the pictures and PLEASE FEEL to continue to rendering your opinion.
I tried posting a short video that depicts water seeping through the cracks, but the site won't allow .avi extension files
JM
G
Guest
Leaks
I recommend a trained marine surveyor's eye look closely at those cracks. The keel stub on our boat model is solid FRP and I suspect yours is the same. Those cracks do not look normal to me (untrained eye).
When you were purchasing the boat and had it surveyed did everything around the keel and stub joint look normal? No smiles, separations, cracks or otherwise? Something appears to have stressed that particular forward keel bolt. It should not crack like that. If water appears to be coming in through that crack, the keel stub joint might be compromised, which means the keel needs to be re-beded.
Our boat bilge area does not have cracks around the keel bolts. You might also forward these pictures to Hunter Marine Customer Service and ask them for their opinion. Knowing Customer Service like I do, they might have already looked at them. Who knows you might receive an unsolicited e-mail from them most any moment.
Terry Cox
G
Guest
Leaks
Just another thought after looking at your pictures a bit more, which are very good by the way. I believe the only way sea water can come in through those cracks around the keel bolts is if the keel stub joint has been compromised. To correct this problem the right way IMHO, is to lift the boat off of the keel, rebuild the stub to repair those cracks, clean up the joint and re-bed the keel. Again, Hunter Marine Customer Service should weigh in here with their opinion, or at the very least a marine surveyor. Sea water should not be seeping in through those cracks.
Terry Cox
bob sims
leak else where
Since the bilge remained dry after you had cleaned it from your last time out, my guess is that water is entering the bilge from a source other than around the keel bolt.
Apr 12, 2009
8
I am going out to the marine tomorrow to check the bilge. It will probably be completely dry. lets see. Any thoughts of where the source could be?
G
Guest
Leaks
What's the flavor, fresh or salty? In an earlier post you indicated that you had a video of water seeping through the cracks.
Terry cox
Apr 12, 2009
8
The water was kind of salty, but interesting enough not real salty. I could not post the video because it’s a couple of Megs. I could email to you if yiou are interested.
Jun 6, 2004
21
Tayana 52 Ft.Pierce, Fl
Our stern gland leaked a bit and the water 'disappeared' down a hole just aft of the engine compartment. There was only one place for this water to end up and that was in the bilge, consequently, even though I would pump out the bilge and dry it, whenever the engine ran, the gland would leak a bit more and water would end up back in the bilge. Is it possible your water in the bilge is coming from somewhere else, other than the cracks shown?
