no problems here either
Stuart,I've had 1990 C28 Hull #7 for 2 seasons now. I still have 2 non-used chainplates on the cabintop, but I just use them for hanging things down below and as spare halyard attachments. According to Catalina, my mast was replaced by Catalina sometime after production when the dismastings were taking place. I have a upper topsides hull repair that's slightly noticable when I'm waxing and have my eyes up next to it that makes me believe she may have been one of the early dismastings.Anyway...the mast Catalina fitted her with is a single spreader rig with the uppers and all 4 lowers to the inboard side of the deck. It is also fitted with the halyard exit slot reinforcing plates at the halyard exits which are about 4-5' off the deck. This is a factory recommended strengthening upgrade that you should check for. A picture of the upgrade is at the C28 web site.All in all I have had absolutely no trouble with the rig. I was hit by a large gust (highest number I saw on the meter was 35 cause I left the helm to lower the sail) last summer that was strong enough to shred my dock neighbors main. My plastic track slides sheared off leaving the main flogging, but the sail and rig held up perfectly. $4.50 to replace the slides was the only damage.That's higher than the wind that many of the dismastings occurred in, so I'm convinced that Catalina addressed the problem correctly.Catalina said the first 12 hulls had mast replacements from the factory. If you don't see the reinforcement slot upgrade on an early boat, call Catalina and ask about that hull and what was done with the rig, but if it's done I think the boats are great!Mike ElmoreWindward HullC28 - Hull #7
