Depth Sounder
L
Larry
My boat is equiped with an SR marine depth sounder. It is reading five feet all the time. I checked the transducer and it reads open. This seams bad. Anyone got an idea what the Ohm Value should be?
Oday 302 Little Current
My boat is on cradle so cannot help out with ohm readings however...
On my model (1987) the depth sounder cable was joined with a BNC connector under the starboard cockpit locker. This connection was dicey, because of location open to being abused and did pull out. We rewired the connectors and fixed the problem. (My guess the original Datamarine cable was not long enough to get back to the wheel so Oday spliced in a connection). Good luck
