depth sounder failure
Ron
I installed a new Signet transducer and guage on my 1985 C27 because of deep water failure. The new unit performs no better than the old. The unit is accurate at shallow depths but will blink at depths greater than about 20 feet with engine on or off. The guage was rechecked by Signet. The lead on the transducer is coiled in a 3 foot figure eight and does not work any better when laid out. The depth trasducer is mounted just off center next to the universal engine and slightly behind the keel. The Signet water speed sensor is located in the bow. Presumably this was the original factory setup. There must be a 1000 boats with a similar setup. I am wondering if the depth transducer should be in the bow where the speed sensor is?
W
Wendell
Air or paint will attenuate results
Is your transducer thru-hull or transom mount placed in a pile of silcone inside the hull? I have installed Garman versions of both types with equal results in saltwater - about 50 fathoms. If air is next to the transducer face or the face was painted along with the bottom, depth readings will be affected. Before installing either 'ducer, I dangled it over the side until the face was in water. This confirmed the unit was operational before installation.
Ron
thru hull tranducer type
This is a standard thru the hull Signet transducer.
