Depth Sonder Transducer Placement
JCAL
Dec 14, 2008
81
Hunter 27, 1990 Lake Charles
If you had a choice where would you place the depth sounder thruhull transducer. midships, aft, forward of the keel? Would you place it on the center line or port or starboard???? Jim
Dec 2, 1999
15,184
Centerline forward of the keel.
Jim: You want to have it forward (for obvious reasons). You also want to keep it as close to the centerline as possible. If you have it midship (either side of the keel) and you are healing 20-25 deg. you are probably not going to get a very good reading. If you are not close to the centerline and forward it may be out of the water (more than in). Of course this all depends on how you are mounting it too. If you are going to glue it to the hull or cut a hole for the transducer.
JCAL
Dec 14, 2008
81
Original Placement
Thanks Steve The broker or MFG. mounted the orginal one about 6" aft of the packing gland and mid-way in the port locker under in the aft birth of my 1990 H 27. I have stripped all chop strand mat off of the bottom (blisters) and decided I didn't like the placement of the transducer and wanted ideas for better placement. Your idea makes good sence. Thanks!
Mike
Ditto
My Data Marine depth sounder manual says to mount the transducer as far forward of the keel as practical. My knot and depth meter transducers are mounted side-by side well forward. An aft mount for a depth meter sensor makes no sense to me at all. Mike
