David
I have a '88 H33.5 in which I am replacing the depth meter and transducer. The transducer is bonded to the inside of the hull approximately in the rear portside just off the centerline behind the engine. (appx. 25 feet aft). I am considering mounting the new transducer beneath the forward V berth for ease of mounting and also to get depth data more forward to possibly avert a grounding situation. My concern is that pitching may adversley affect the accuracy of the data as compared to mounting more amidship where pitching would be less of a problem.... I plan to fabricate a housing filled with mineral oil in which to mount the new transducer inside the hull. What do you think?? Any suggestions or feedback would be appreciated.David'88 h33.5"South Wind"
