I have a MacGregor 26S (water balast). I want to purchase a Larance combination GPS / Depth finder and use an"shoot thru hull" transducer so I can avoid a thru-hull mount.
With a water balast configuration, where is the best location to mount the transducer inside that will give a good signal without balast tank interference?
I know the lazarette is a possibility close to the forward bulkhead but think that mounting further forward might be better.
I do'nt think I wat a transom mount as the back of the boat can come out of the water depending on loading, wind, wave actio, etc.
Anyone else had experience with this that could share would be appreciated.
