Wiring the Depth Sounder
Randy: If you look at the photo that I uploaded before, you will see a switch inside a little black boot, just to the left of the depth sounder, and below the 4 fuses. This switch turns this blue panel on and off. It turns the power to the Depthsounder, autopilot, autopilot remote, and a 12 volt socket that is behind the panel on or off. (The red and black wires that you can see inside the coaming compartment are to the 12 volt socket that the adapter to the GPS plugs into). When I turn the master power inside the cabin off, this panel also goes off, of course, but otherwise, just this panel will go off with this switch. Relative to your question about not covering the depthsounder, you're asking the wrong person that question. I even cover my mast when I trailer the boat. Anyhow, do motorboaters cover their gages when they aren't using their boats? The depth sounder looks like a motor boat gage to me. (The motorboaters in my marina do cover their gages when they aren't using their boats).On your question about a wireless depthsounder, I like to run wires. I have 120 volt wiring in my boat too. I only cut one receptacle into the area near the head, but I have another one opposite the battery box, inside the step under the companionway. We plug in a battery charger into it when we are cruising. As I said, I like to run wires. I work for a connector company. I never noticed that there was no "G" in Humminbird. By the way, I really felt good about NOT drilling a hole through the hull for my depthsounder. The tranducer was made for transmitting through the hull without drilling a hole for it, and it said that it was. I guess other ones can do this, but this one actually said that it was made to shoot through the hull. Aldo
