depth display on lap top?
637
Oday 23 Anna Maria Isl.
If I were using a lap top hooked to a GPS for navigation, would it be possible to get the computer to display depth (as read from a transducer)? How would I do this?? Thanks a lot!
Feb 17, 2006
5,274
It depends on the language spoken by the transducer. GPS is NMEA 182 sentences. If the transducer speaks the same language you should be good to go. Check with the manufacture and see how the data is sent. Some systems will allow you to interface with a PC or other devices. Does yous? Mine does not.
Jun 6, 2006
6,990
Would need to know the type of depth
nm
Joe
Jun 1, 2004
8,323
Check to see if your nav software supports it.
