Something I've been wondering about for a few days and thought I'd ask the expert before I play with it.
Because I have roller furling, my approach has always been to reduce sail, or have the right amount of sail up and keep "normal" trim on it like keeping the vang tight when I want to depower the rig to reduce weather helm. Now I'm wondering if it's better to instead of reducing sail, to loosen the vang to increase the twist. Both methods will move the COE forward, but now I'm starting to think that inducing twist will move it farther forward then reducing sail. Thoughts?
Note: my boat is a tall 7/8ths fractional rig with about twice as much sqr ft in the main sail as the jib, so adjustments to the main is where the performance gains are mostly at. Jib pretty simple....tight jib sheet until inner taletails start flowing (as outters usually start to flow first).
