John M. Moe
Dennis,The picture you posted in answer to the question about mast/boom connections is identical to mine. Where you have a bolt with a wing nut through the boom is where, I assume the tack of the main should be attached. the bolt rope holds the tack cringle too high to pass a pin or bolt through however. My question is How do you attach the tack of the main to the boom. is there a fitting of some kind that I don't have?Thanks!John M. Moe
