I will be replacing about 8ft of core material on the starboard gangway. I guess it's had a lot of traffic over the years with 250lb guys running back and forth on it. It's a non slip area about 10" wide. I'll be working from inside the cabin which mean working on my back. I'm not confident on the quality of my work to work from topsides and remove the top skin.
I was thinking of replacing the rotted balsa with 9mm Marine Meranti ply at 106$ a sheet. Another option is outdoor Overlay Signage Plywood at 60$ a sheet, which is not 100% free of voids, but is an outdoor commercial sign material and the seller says is better than ourdoor fir ply. I can vouch for the long life of this material. I have a piece for the bottom of my lawn tractor trailor that sits outside in all weather. I built the trailer in 97 from 1/2" board, and it was already a 1982 sign.
I could also saw a million 3/8" eastern cedar qtr sawn ends out of a 2 X 8, then clamp them all to make a large surface, but that's not practical.
You guys see anything wrong with using this marine ply for core material?.
