C
Charlie
I recently purchased a 1985 Hunter 34. The engine would start to smoke at about 2800 rpm and then stall. It would run all day at 2500 rpm. I read that lack of air causes black smoke. The air filter was clean amd no rags or dead rats in the intake. I opened the engine hatch and discovered that under full load (15 x 15 prop) I could get 3200 RPM and it would rev to 3800 RPM with out a load.Where is the air supply vent for the Hunter 34. I have a small vent in the starbard side but a previous owner had installed a deisel generator and it is used by a fan to blow air to the generator. This was the only opening that I can find that might have supplied air to the engine and I am not sure that it was supplied by the manufacturer.What was the design intent to supply air to the deisel engine? Has any one else had a problem? What is the Cure?All answers appreciated, even smart allec ones.Charlie
