Dehumidifying
56
Columbia 8.7 Potomac
The interior of my boat smells a bit musty.
I know the source of the moisture, the forward hatch has a persistent leak (that I hope to stop soon).
Not an issue if I keep it covered.
So I was wondering if it made any sense to leave a dehumidifier running in the boat?
I was thinking it would drain into the bilge (a bilge pump is left on auto mode when the boat is docked and unattended).
Is this just going to cause a moisture loop?
Nov 6, 2006
10,121
That can work very well to dry things out. I used one for a few years . I secured it next to the sink and drained it into the sink.. I had to be careful with the humidistat because it could dry things out so well that wood started warping.. Today I have a dehumidify cycle on the air cond . It drains into the bilge and it has not caused a problem with a moisture loop.
Welcome aboard ! This is a fine forum.. Well run and well participated in
Jul 11, 2013
56
I didn't even think of the sink!
Thanks!
The sink just drains overboard, right?
Thanks for the welcome :)
Sep 6, 2007
324
Catalina 320 Gulfport, Fl
I drain mine in the sink, and to prevent it from getting too dry I pug in one of those dial timers then plug the dehumidifier into it. I set it from 6 = 10 am then 6 = 10 pm. The wood does not shrink and my screws stay tight.
