Deep cycle battery options...
Oct 28, 2013
132
Catalina 42MKII Fairfield, CT
We currently have 2 new group 27 batteries, with a new 50w solar panel. We have a great (new) refrigerator that does not eat too much power at all, and the solar panel which is able to get both batteries to 13.7-13.9 in a few hours. We do not travel that much when not plugged-in, but do have a LED tv/AppleTV, laptops, and phones. I was thinking of adding a 35 AH 12v battery with a 4 position switch after the solar panel controller to divert to the batteries. Would would you recommend: a single 35AH battery, 2 of them, or a just one with a higher capacity of 50 AH, or 100 AH? Thanks!
Apr 26, 2015
663
S2 26 Mid On Trailer
How do you know how much power the refrigerator uses? Why exactly do you want to add two small batteries? Do not travel much????? I'm not trying to be an ass here but be a little more specific on what you are trying to accomplish may garner a few more answers. Keep it simple (KISS) and add more batteries to the house bank (keeping starting batteries separated) and understand that 50 watt solar ,where you live. will probably (IMO) never keep up with the load of a Hunter 35 . You could spend the money and do a power assessment with all of the expense of the required monitoring equipment or just wing it like many people do. Go out for the number of days you like and see how the batteries held up and if they got low add another one or two. Just be careful about adding new batteries to real old ones in a bank.
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
For your reference: I have a 25' Catalina and use 2ea size 24 batteries with 160 watts of solar. A reefer, TV,etc will eat your 50w panel! No more batteries......you need 200w solar and go from there. Chief
Sumner
Jan 31, 2009
5,254
... A reefer, TV,etc will eat your 50w panel! No more batteries......you need 200w solar and go from there. Chief
Agree....
http://purplesagetradingpost.com/sumner/macgregor2/inside-22.html
200 is probably about minimum for a fridge if you are out for more than 3-4 days at a time. At least that is what I found using the compressor fridge on the Mac above. I have over twice that now (560 watts of Solar and 4 batteries).
http://purplesagetradingpost.com/sumner/endeavour-inside-mods/inside-index.html
The fridge/freezer on the Endeavour is about twice the size but get by with less amperage due to a lot more insulation, so it will depend on how long you want to be out and how good the fridge is,
Sumner
1300 miles to The Bahamas and Back in the Mac...
Endeavour 37 Mods...
MacGregor 26-S Mods...
Mac Trips to Utah, Idaho, Wyoming, Canada, Florida, Bahamas
Oct 28, 2013
132
Thanks for the OPTIONS! I have voltmeters on each of the 2 batteries that came with the boat, and based on us traveling overnight on moorings (not plugged-in) and saw that running our refrig during the night (24x7) we go from 13.2V to 12.2V (lowest). During the day, we either power out of channels/marinas, or the solar panel seems to be bringing both batteries to around 13.6 - 13.9V in a few hours. Our main battery switch does not work properly and I cannot separate bat 1 from 2...and I am not looking to rewire, the AC/DC panel looks pretty scary... Just based on that, I thought that the solar panel is "doing its thing". We have not had ANY issues starting, so far during the entire summer season. When we are at the dock, we always plug-in and use our regular charger to re-charge. I was looking to have a deep cycle house battery just to run our non-critical peripherals: TV, phone/laptop chargers. I am also a big follower of KISS principle, and was hoping that this would be a simple dedicated add (through a separate 4-position battery switch). The new battery switch is to be able to toggle between where the solar charging will be directed toward, either the "house" battery, or to the main 2 batteries.
What you are proposing is not at all KISS.
The simplest system consists of a dedicated start battery and a large house bank. Each bank has a simple on/off switch and connects to a third switch like this Blue Sea Model. The alternator, charger, and solar all lead to a positive bus bar that is between the switch for the house battery and the Blue Sea switch. The start and house battery are combined with an ACR. In words this sounds more complicated than it really is. Somewhere MaineSail has posted a nice easy to understand schematic.
The value to this system is that
1) it keeps house and start batteries isolated,
2) with the turn of 2 switches the electric system can be run from either bank with the remaining bank isolated,
3) when any charge source is present, both banks will be charged as needed,
4) with proper placement of the isolation switches the system is pretty foolproof, the alternator cannot be disconnected while the alternator is running, preserving the alternator diodes.
The schematic I mentioned is posted on this forum, I just can't find it quickly.
Likes: Scott T-Bird
This is the part that makes no sense.
You want the solar to go to the house bank.
You want the biggest house bank you can "make."
What is the difference in your mind between the "house" battery, or to the main 2 batteries?
These might help:
OEM 1-2-B Switch Wiring History http://c34.org/bbs/index.php/topic,4949.msg30101.html#msg30101
Basic Battery Wiring Diagrams This is a very good basic primer for boat system wiring: http://c34.org/bbs/index.php/topic,6604.0.html
This is another very good basic primer for boat system wiring: The 1-2-B Switch by Maine Sail (brings together a lot of what this subject is all about)
http://forums.catalina.sailboatowners.com/showthread.php?t=137615
This is a newer primer for boat system wiring design with a thorough digram: Building a Good Foundation (October 2016)
http://forums.sailboatowners.com/in...dc-electrical-foundation.181929/#post-1332240
The Short Version of the 1-2-B Switch Stuff: http://c34.org/bbs/index.php/topic,5977.msg38552.html#msg38552 This is a link to the Electrical Systems 101 Topic, reply #2
What are ACRs, Combiners & Echo Chargers? (by Maine Sail) [scroll to the top]
http://forums.catalina.sailboatowners.com/showthread.php?p=742417 and http://c34.org/bbs/index.php/topic,9404.msg70131.html#msg70131
