ok it's getting hot down here and i have onboard ac .....now it is wired in the the maine panel...via a 30 amp single breaker on the acv panel......i am wondering how to add an extra shore power cord through a new 30 amp deck fixture ...that's the easy part...but when i feed the power to the panel should i treat it like a maine breaker on its own or can i wire the hot leg to the single pole breaker and connect the neutral and ground to the buss bars that are in place now granted i isolate the breaker from the grid in my panel or do i need to have an extra maine breaker in the panel on its own and then a single pole breaker from there to the ac ...its a power hog and makes it hard to run the micro wave and the other things at the same time...i do have an extra dock side outlet available ....i will have to check and see that the two outlets or not on the same hot leg at the dock
