Pressure Water Installed, with a few problems
Pulled the boat in front of my deed restricted house and worked for 5 hours in 90+ degrees with a box fan blowing on me, but I did finish the install. Delivery delays and lack of time made me miss the cooler spring weather we had here in Florida. A couple of surprises/problems: the cockpit locker has foam flotation on the sides (at least where I wanted to mount the deck shower) so I ended up enlarging the original sink pump hole (my new whale faucet only needed a 1 inch hole) to mount the shower horizontally versus vertically. The closed shower compartment sticks up less than a 1/4 inch and has a 6 foot hose to pull into the cockpit, so that worked out. The anchor locker is not cored and was nearly 1/4 inch thick so the deck fill went in pretty easily (with some extra help from a file around the edges). The last problem I had was DC vs AC. Black is hot in a DC system and I was tired/hot, but I realized it as soon as the battery arced a little. One last problem, again due to the heat, was leaving one hose clamp off when I turned the pump on. Pumped a half gallon of water under the sink before I realized it. Remedied that and stood in the cockpit hosing myself down with the 3 gallons of water I had put into the 20 gallon plastimo bladder up forward. Promised my wife a late lunch at the local Mexican Restaurant with margaritas if she cleaned up.
Ready for a 5 day July trip in Charlotte Harbor,
Ed
