Deck Water Impregnation
G
George
I think the deck below my mast has been impregnated with water. Has anybody had this problem? Is there a way I can repair it? If so can you suggest any solutions?
J Olson
leaking mast
Hi George I have aC 30 and my mast leaked throw apipe that the mast lights go up and rotted a spot at the bace of the mast . You have to remove the mast and the mast step bracket then drill holes under mast step remove rotted wood and let dry then wash with acatone and fill with epoxy then grind top smooth and put a layer of glass. if its not to bad you mite be able to keepthe work under the mast and seal it with epoxy . my boat has as iner mast suport that is part of the head liner I did not no to check it and it is compressing and will need to be fixed this year. But I love sailing LG I am mored out on cleverdale point in catskillbay .If you want to E mail me we can exchange Phone # and I m shore I can be more help Meow10950@ Yahoo.com PS You have to fix this asap John Olson
