David
I recently purchased a 1985 Catalina 30. The survey noted several small hairline cracks 1 or 2 inches long in the fiberglass support beam at the top of the compression post. I had the mast pulled and the step checked by a reputable yard, and was told that the hairline cracks were the normal result of stress from the deck-stepped mast and that if repaired they would probably reappear. Any experience with similar small stress cracks by the compression post and suggestions on whether this is normal for a Catalina 30 after 15 years, and what repair is indicated and feasible?
