I'm getting ready to repair a bunch of spider web cracks & a couple of areas that need structural re-enforcement on the deck prior to paint. Seeing how my hull is polyester resin, it seems logical to me to continue the use of this product w/ a high density filler like West 404, which I already have. I'm priming the grinded out areas with Interlux 2000 prior to filling/fairing.
Some of the stuff I've read about deck repairs suggests using epoxy w/ low density filling/fairing compound like West 407, other articles recommend the use of a vinylester filler to patch & fair the gel coat areas.
Is there any reason why I can't/shouldn't move forward using a high density filler with polyester resin? Once it's cured, I'd wipe it down w/ acetone, then soap & water prior to laying down the paint undercoat/primer.
Thanks in advance,
Bob
Thanks in advance,
Bob
