Don Bodemann
Friends,When I hear many folks cutting "panels" out of the underside of their decks to remove soft wood, I wonder about the lose of strength. I think of a cored deck as sort of an "I" beam or truss and the strength coming from the whole structure. If you cut the bottom leg off an "I" beam, the beam will lose 75% of its strength. Now in the case of a cored deck, I realize we “glass” back in the lower panel, thus restoring the bottom of the “I” beam,….BUT this glassing back in of the lower panel, is a “secondary” bond and only half as strong as the original skin at best. Now let’s consider the core material that has been reduced to mush. Its only job is to withstand “compression” which of course it doesn’t do as mush. I have come to the conclusion that the best way to repair a soft deck, no matter how bad it is, would be to use the “drill holes and inject epoxy” method. I realize drilling holes in the top surface rubs some of us wrong, as we’ve been fighting water intrusion for years and water intrusion is what caused the problem in the first place! The field of small holes will not significantly compromise the strength of the top skin and sealing these holes should not be an issue. I realize I’m challenging conventional thinking and welcome the opposing explanation from those with more experience.Don .
