Last week I cut into my deck under a turning block because of some wet plywood when drilling out one of the holes. I figured I would cut into the laminate directly under the block (about 2" X 6") to see how far the dampness had spread. Well I ended up with about a 6" X 7" cut into the fiberglass and there is still more damp wood to be repaired. The area I was cutting into is in line with the mast, beam direction that is, not for and aft. Come to find that Catalina put in 2 1/2 " of plywood in there(what were they thinking?). I'm sure that there is this much plywood all along the line athwartship of the mast as you can see the form the headliner takes on the inside of the boat. I suppose they were building up the thickness to support the mast. Not sure they need this as they have a compression post to handle mast load. I wished they would have tabbed in a wood beam on the inside of the boat or someting else more easily repaired. I dug down to the bottom skin which forms the headliner inside the boat. This headliner is quite thick. I would estimate it to be almost a quarter inch and quite solid/stiff. I ended up putting in 5 layers of 1/2" marine plywood, epoxied in place. I have a lot more work to do. I'm sure the area under the mast is wet. They have mast head light wiring running through the mast step plate and runs in between the inner and outer skins and I'm sure water has gotten in through the wiring opening. The wood I dug out was damp but not rotted. The area around my mast does not show any signs of compressing into the fiberglass. This was the same thing I found when digging out the inch and a half of plywood from the keel sump, wet but not rotted. Catalina sure loved to put in a lot of plywood. It'll be enjoyable to get into the area where there is a normal deck core thickness. To be continued.
