Deck mounted windless foot switch
3
beneteau 390 Salt Spring Island
My Beneteau 390 has a deck mounted air foot switch for the windless
Can not find a replacement only electric switches seem to be available.
I would prefer to replace with a air switch
Thanks for any information
Jun 6, 2006
6,990
They don't wear out much. I don't have a source either. You might be able to repair it.
All it is is a hose connected to a bellows. If the hose is busted just replace it. If the bellows is cracked try rubber cement and a bike inner-tube patch.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
go to the hot tub store and see if you can find a switch that you may be able to cannablize and inter face it in you old switch housing ...the last i checked thats all they use on the hot tubs.....it may be worth a try at any rate.....
regards
woody
Feb 9, 2008
292
Catalina 22 Long Beach Harbor, MS
Drain cleaning machines have air operated foot switches. Duracable is a major supplier. Here is a link for the catalog pdf:
http://www.duracable.com/DuracableCatalog.PDF
On page 21, the foot pedal is part number 25074, and the air actuated switch is part number 25061. Hope this helps and is compatible.
(Or get a child's ear cleaning bulb and attach a hose. Ha.)
Aug 14, 2011
3
Thanks to you all I will try the repair first
