Deck leaks oday 322
Jon B
I am having trouble finding what appears to be a substantial rainwater leak somewhere on the boat (322). Any Ideas advice would really help.
Oday 35 Toronto, Ontario
Same problem..
on my O'Day 35. While it was pouring rain in the fall I happened to be in the quarter berth servicing the batteries and noticed one of the DC plugs at the base of my pedestal on the floor of the cockpit was leaking very badly. I relocated it and plugged the hole. That seemed to help but I'm still getting water from somewhere and the boat is on the hard. I suspect its leaking around the keel stepped mast.
Jeff
Been fighting
A leak all winter on my 322. This time turned out to be one of the cockpit scuppers. Access by taking the back panel off in the aft cabin, or can access through the lazerette. In the past I've re-set stantions and replaced the shaft packing with a dripless shaft seal. Good luck. Jeff
