Removed the rub rail Saterday. The entire length did not have any adhesive on the deck. You can tell alot of water and dirt got underneath it.The seam for the deck and hull is in poor condition as there are many gaps. It looks like very sloppy work with little adhesive between. I can tell, especially in the bow that water did come through the seam into the anchor locker. I figure that I will grind the edge slightly just to clean it off, put 5200 in the seam and clamp it together prior to putting on my new rub rail.Greg P36-2 #101
