O
Ozana
I have a leak in the aft cabin, the water runs down behind the liner and soaks all the foam bed. The boat is a 1995 35.5 Legend. Someone told me that the leak most probably comes from the deck/hull joint. A solution he offered was to remove the aluminum toe rail and pry open the joint (a bit) remove the old caulking (5200) and reseal with 5200.I have re-tightened all the bolts already.My question is if anybody has experienced the same leak and if you have removed the toe rail to fix it. How long? Did you have someone do it and how much?Also I'm considering putting Dri-Deck Panels under the foam bed (untill I fix the leak) to allow water to run under the and not soak them. They are expensive ($4.99 @ sq.ft., so does enyone know of a similar cheaper product?Thanks in advance.Ozana Halik
