Deck hatch replacement
1
Hunter 22 Home
I just purchased a Hunter 22... and am having to replace the deck hatch. I have not removed the hatch itself as of yet, and was hoping to find out the measurements of the INSIDE of the hole in order to find a replacement before lifting it out. I have the manual and could not find where it gave the measurements to the deck hatch. It looks like it's a perfect square and my rough measurement was about 16", but this is not exact and I know I need exact. Any help would be greatly appreciated. Thanks!
Ray T
Jan 24, 2008
224
Hunter 216 West End - Seven Lakes
re: hatch replacement
I am not familiar with your boat but I would like to offer some suggestions. Are you able to lift out your hatch without destroying it? if so lift it out and get your measurements then drop it back temporarily while you find a new one. Some hatches are molded into the deck with just a lid in which case measurements should be easy. I would also suggest you start looking at some of the places that sell used boat equipment you might find a high quality hatch that fits your budget. One last suggestion, If you have to destroy the hatch to get it out you might consider going ahead and doing it, you would then have a clear idea of what you need. This would be my last resort but I would do it if I thought I could get away with it. Anyway I wish you good luck in your project. Ray T
Feb 24, 2007
32
Hunter 23.5 Beaufort, SC
If 5200 was the sealant..
BE careful removing your hatch. You might end up ripping the gelcoat up and doing damage if you aren't careful. I know opinions differ, but 5200 is not allowed near by boat. I learned the hard way.
When I removed the hatch on my Precision 21, I used a new razor knife (long retractable blade) and 'sliced' and as I pulled the frame up. It took a whlie and I still ripped the gelcoat from the fibreglass in a few places. Repairing the damage isn't a difficult repair but it does take time to get everything smooth and even. Besure all of you old sealant/adhesive is removed before installing the new hatch. I had my hatch a head of time and it still took 2 days, due to the gelcoat repairs, to get the hatch back in properly.
I repaired my gelcoat damage by using resin and thickening powder. Marinetex or any 'marine' 2 part putty would work. Avoid 'Bondo'.
Why can't you measure from the inside. I was on a H22 20 years ago but I don't remember the hatch. Is there a 'trim' piece that could be removed to so you can ge a good view of the opening?
I have a friend with a H22. I'll mention this thread to him.
Good Luck,
Mike
Jun 5, 2004
23
Hunter 22 Acworth/Atlanta
Mike sent me an email about your post but I would have to try and do what your doing at this point. I'll ask one of my fellow club members and see if he has any suggestions. He was sailboat broker and has given me some good advice.
