Deck Hatch Gasket Needed
okiman
Oct 1, 2005
77
Hunter Cherubini 33_77-83 Okinawa, Japan
I am refurbishing a 1978 HC33. I removed the two deck hatches,painted them and replaced the plexiglass. Now I need to replace the round, black, dense foam gasket material. The diameter of the gasket is 7/16ths. Does anyone know where I can buy this stuff? Thanks
87
Hunter 33_77-83 Montevallo Al
H33 hatch gaskets
Several years ago, I simply stuck a round of adhesive backed foam weather stripping gasketing directly over the old original gasketing as an interim measure. Since then, the overlayed gasketing has done such a good job I see no need to change it at all. I believe that the thickness of the foam insulation was probably not over 1/4". The hatches are Bomar and I believe that West Marine may be a source of the original gasketing.
Dec 3, 2003
2,101
Hunter Legend 37 Portsmouth, RI
You can also check:
http://www.pompanette.com OR the Boat/US Special Orders desk (for a better member price).
Jun 5, 2004
242
None None Greater Cincinnati
D-gasket
I think this comes in 2 sizes - small for the 9inch hatches and larger for the main hatches. You will need to check the size you have (or estimate what will fit.)
