Steve Voyce
I plan to run my spinaker halyard back to the cockpit through a deck organizer and a clutch. Can I mount the organizer and clutch using sheetmetal screws so I don't have to disturb the overhead or should I use fasteners that pass all the way through the deck and secure with nuts? If I do use nuts and bolts should I cut larger circles in the overhead so I can use a socket set to tighten the nuts against the underside of the deck?Any ideas? thanks steve
