At our last pump out, the waste cap was frozen so tight, it broke into a million pieces and also damaged the threads on the deck fill (ok, I damaged them getting the cap remains out).
Unfortunately, on our P303 all of the deck fills have a 3-1/2" diameter flange and a 2" hole on the inside of the cabin. Almost all of the new fills are a 3" flange and take a 1-3/4" hole.
I was lucky and found a waste fill (Whitecap) at West Marine with the dimensions needed, but now am wanting to replace the 30 yr old water and diesel fills.
Does anyone have a source for deck fills of the appropriate size (no, I don't want to use a "waste" marked fill for the water) ?
Or should I try to fill the existing deck area and re-drill for the newer dimensions ? If so, what would be the best way to fill the gap ?
Thanks!
--Charles
Thanks!
--Charles
