Deck fill caps
21
- - Huntington,NY
I have a 1983 Catalina 30TR with the "no longer available" black plastic deck fill caps. They were make by wilcox critteden and are stamped 1 1/2 " WC on the inside. I do not which to change all the four assemblies which require new drilling and bedding. I have tried 4 local marine supply houses, WC, Defender, Catalina Direct, Catalina parts (which hasn't responded) and am ready to give up. Does anyone know a source?
Kadima
Feb 14, 2008
8
Catalina 30 Atlantic Highlands, NJ
Similar problem
I am having a similar issue replacing the cover for my shore power outlet. I have a 1978 Catalina 30 TR and the cover was pulled off. The only replacement parts sold after market require that I rebed and do some fiberglass work. I would love to find shore power outlet the same size so that I do not have to make any cuts. I continue to do my research and will let you know if I find anything. Please do the same!
May 24, 2004
7,213
CC 30 South Florida
Not that I know off and did look for years.
Your best bet may be to replace the filler tube. They sell for about $30 with cap and hook up to 1 1/2 inch hose.
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Here ya go...
http://www.iboats.com/SeaDog_Flip_Key_Keyless_Colored_Deck_Fill_Caps/dm/cart_id.316274119--category_id.238186--list_time.1209767838--session_id.379332833--view_id.39783
