Deck Drain is clogged
9
Pearson 303 Fairfield
Pearson 303.
The port side deck drain is not draining! Is there a valve somewhere that controls this or is it just clogged? Any help would be great.
Thanks.
Feb 13, 2010
8
Pearson 30 Ashbridges Bay Yacht Club
If it is anything like my Pearson 30 then it is just blocked. Straighten out a coat hanger a poke all the crude out. But be carefull doing so.
Nov 9, 2008
115
Pearson 323 Bayfield
On a 323...
I have the 323 and the deck drains have a 1 1/2" hose to a non valved through hull just above the water line. (Doesn't meet ABYC standards today.) Mine were very flimsy hoses and one was cracked when I got the boat. Be a little careful with your coat hanger and check the hoses. The through hull is close enough to the water line to get you in trouble if there's a leak.
Geoff
Apr 25, 2010
5
Pearson sloop Galesville, Md
I have a P28, whose drains clog sometime, I simple get the water hose place it over the drain and put the jet spray on works everytime. Try it
Feb 18, 2010
9
Thanks! I was able to clear the drain, I bought a mini plunger and it worked like a charm....lots of junk in there....
Apr 25, 2010
5
Water Hose
Gail R
Apr 22, 2009
261
Pearson 34 Freeport, ME
We've done the water hose trick on the deck scuppers. Works like a charm (provided it's just a few pine needles/leaves and your scupper hose isn't... hosed). We also have occasional probelms with the sink drain in our head getting clogged. Did you know that a beer can coozie makes a great mini-plunger? Just place it upside down over the drain, cover the bottom with the palm of your hand, and push. You might want to put a small towel over the coozie/hand assembly before you push to reduce splash.
