Deck delamination
bobbob
Jun 17, 2012
4
pearson 31 noank
We have a 1987 pearson 31, stbd side deck creaks, suspect delamination of plywood. Any ideas out there for repair/drying out of the deck?
Mar 14, 2012
52
I had a similar problem on the foredeck of a previous boat. In that instance, I drilled several holes throughout the delaminated site and let it sit a few days (she was on the hard and I had a few days of nice drying weather).
I then went back with a bent nail in a drill as if I was going to rebed a deck fitting. Then filled the holes using West system epoxy and glass threads. Once dry, I sanded the epoxy/glass. Had to repaint the deck and used filler in the paint to match as best as possible the deck pattern. It was not bad, and you could see it if you were looking for it. But it was solid again and it didn't leak.
Good luck.
Ed
Hope that help
Jun 19, 2012
10
Yeah. That's the standard repair refine for a soft deck. Other options, like re-coring are a lot more involved and don't really yield significantly better results.
Dec 5, 2010
1
Pearson 31-2 Pleasant Prarie
I also have an 87 Pearson with the same issues, what size drill holes did you make?
Keep us updated on which rout you take and good luck Bobbob!
