W
Winters
Have some delamination on both sides of deck near chain plates. I understand the repair procedure, but would like to know what, If any, laminate is between the deck. I have read many, many of the repair procedures on this model boat. Has anyone completed this repair? What products and what procedure was followed? I have had advice from many, but none that repaired a H-31. I was told you can access from beneath or through the deck. I must travel several hundred miles to do this repair and I would appreciate a heads up on any techniques or expertise that is out there. I don't know what to expect...balsa? marine plywood? fiberglass? I am going to repair this on 4/5/02, so I need any and all ideas quickly, please! Also the hull has some damage, but that is a little clearer. Thanks in advance for your input.....
