deck connection for masting lighting
L
Larry Weber
I need to replace the male portion of the deck connection serving the electrical wiring within the mast. Two problems: a]having a hard time locating the needed three pole fitting. b]there is virtually no slack wire coming out of the deck and going to the existing fitting making replace of the existing fitting vry dicey. The wiring seems to be located in an inaccessible channel between the deck and the interior headliner. Thoughts? My preference would be to locate a 3 pole fitting and just replace the male portion, leaving the portion attached to the deck alone. Thanks
Mike
Pin connector
I had the same problem when I had my 25 Catalina. I couldn't find the stock connector so I had to buy a new 4 pin connector from West Marine. I then replaced the male and female. The wires are indeed very short, but you can make it work. Good Luck Mike M C27
