debonding solvent for water tank lid
Jeff
is there a debonding solvent for 5200 or epoxy that wont hurt the fiberglass?im trying to remove the water tank lid and it appears to have been sealed with epoxy or 5200.
Timbo3
Sep 11, 2004
70
Hunter 30_88-94 Tarpon Springs, FL
Goof Off
Epoxy will be a tough one to get off, but Goof Off will disolve 5200 a bit at a time. Used it to get rid of 5200 around a leaky skylite.
Dec 2, 1997
9,011
- - LIttle Rock
When you put the lid back...
Use a rubber gasket instead of any sealant. A gasket actually provides a better seal...and you can remove the lid if/when you need to. Rubber gasket material is available from any hardware store.
Dec 2, 1999
15,184
Don't think it was 5200
Jeff: I do not think that it was 5200. I have removed mine and it was a SOB, but it came off. I suggest that you get a couple of flat pry bars. Get one started and then get a second one going in the opposite direction. Once you get the seal broken, it will lift. I resealed my tank with Life Caulk and it was the same when I tried to remove the lid the second time. I have recaulked this sucker about 4 times and vowed to never do it again. My final resolve was to have the lid glassed in place. Place two inspection ports in the lid and she should be good to go. Be sure to cut all of the caulking away from the edge all around the tank before you start.
Jan 2, 2005
779
Hunter 35.5 Legend Lake Travis-Austin,TX
DeBond 2000
Ad says "DeBond 2000 removes cured 3M 5200". No personal experience. Link follows...
