9.9 More than Enough
Ray, Sounds like you are looking at your first mid size sailboat - the C-27 is a great boat, but you should research the archives to find its strengths and weaknesses.As far as 9.9 hp goes: more than enough. A C-27 is only going to make 6 knots under power anyway, and your engine will get it there quickly. If you sail primarily in rough seas, then you might prefer an inboard, as an outboard can tend to come out of the water in storm conditions - but I wouldn't let an outboard sway me away from an otherwise sound boat. They have some obvious maintenance advantages over inboards.I have a 30hp inboard, which is entirely too much engine. I can rev the engine up all I want, but the boat will not go above 6 knots under power. So I usually cruise at around 1/4 throttle.Hope this helps-Rob
